As you look into the bilge of a 2452 (mine is 1993, 5.7l) through the port and starboard deck hatches in the cockpit, you see a floor of sorts in those locations. They seem fairly sturdy, I have stood on them, and layed down in one of them to slide up under the helm. Quite an exercise in contortion.
Underneath that floor, this whole area extends from the transom up to the main bulkhead. And from the engine stringer to the outboard side of the hull. It is probably a foot deep at the part closest to the center of the boat. So it forms a large cavity at the chine, outboard of the engine stringers, on both sides of the hull.
But my question is what is inside of those? If makes me nervous to have an enclosed area that I can't access or see into. It is a pretty large space, and could hold a lot of water in an older boat like mine.
What I will probably do at some point is cut a 6" circular hole in one of them to see, and then plan to put a screw in deck plate back in there. It seems like there are probably only two possibilities, one is that it is filled with foam, the other is that it is an empty space.
If you have already done this on your boat, please let me know what you found.
Thanks!
Thanks!
