Alternate (automotive) oil filter for Aqua Power 6003?-gctid576644
    So I missed getting to the marine store, and won't be able to until probably 2-3 more days. I'm looking for an alternate oil filter for the Aqua Power 6003. The online cross reference lists several, but none of the local auto parts stores carry any of them:
    AC-Delco PF1194
    AC-Delco PF1794
    AQUA POWER 6003
    Baldwin B360
    Baldwin BT241
    BIG A 92072
    BIG A 92086
    CARQUEST 85072
    CARQUEST 85086
    Fram PH6606
    HASTINGS LF111
    HASTINGS LF283
    LUBER-FINER LFP2274
    LUBER-FINER LP2278
    NAPA 1072
    NAPA 1086
    Purolator L24736
    TELEDYNE RV-51
    Wix 51072
    Wix 51086
    Any suggestions for an 87 OMC 5L?
    For a GM (Chevy) engine any 1968-2000 filter should work. Have the part store look one up for an 1987 c10 pickup with a 305 or 350 engine. Personally from the ones listed I would choose Wix or Napa (also Wix). Mobil 1 and K&N (white not black ) are also quality filters.
      the filter thread is 13/16 x 16 NPT. The o-ring gasket has diameter of 3.25", it runs along the
      outside of the top of the filter.
      Short length filters are:
      Fram PH30, TG30
      supertech st30
      wix51046, wix51069, 51086, 51087
      napa 1046,1086,1087
      purolator per12, per49,
      acdelco pf12, pf2525,
      motorcraft FL10, FL775
      sierra 18-7824
      The long lengths are:
      Mobil m1-302
      Fram hp4, ph5, ph13, ph373
      wix51060-51061-51794
      napa1060-1061-1069
      per40,
      per84pf11, pf35 pf1218, (pf832-932)FL308
      sierra 18-7877
        Buy a quality filter. You can pick some up and tell a diiference in the weight. Look down the center hole, If you see plastic put it back, also the cheaper filters are flat on top, the better ones will have a raised area between the center hole and the ring of holes.Personally you couldn't give me a Fram filter.
          The fram co came a long way.
          I never had a failure, who here has had a filter fail, raise your hand.
          I use them on all my cars also.
            I have replaced half a dozen Cummins engines in Dodge trucks where the filter came apart, clogged the piston squirters, and caused galled pistons and cylinders. All had Fram or Penziol labeled filters. The adhesive came apart clogging the squirters. Not saying all their filters are bad, But you need to look closely at how their made
              My local auto parts store, they've been around since the 1940's, completely stopped selling Fram filters and have gone to nearly all Wix filters. I think I'll go with Wix. Your mileage may vary.
                I put up the wix filter numbers also.
                Give this a read.
                http://www.jeepforum.com/forum/f9/ea...-ohio-1261517/
                  I have been using Fram filters on the boat for the last 4 years, not an issue whatsoever. I will be using Mobil1 over the next several years as I came across a deal for several at $5 each.
                  The short version is what I use as I change them every year and put on low hours (Mobile1 M1-111). The oil is still golden when changed and the filter must still be good for maybe another season so the long version in my case would be a waste. Here is a good place to buy on line for cheap. Shipping is dirt cheap and if you order a dozen it is free. http://www.filtersandwipers.com/m1-1...3-ph8873-m1111
                  Or if on a tight budget. http://www.filtersandwipers.com/ph30...pz3-tg30-m1111
                  Cheers, Hans
                  2007 Carver 41 CMY
                  Twin Volvo D6-370
                  Montreal, Canada
                  Midnight Sun I Photos
