Last year I purchased a used 2006 305 with twin 5.0L 220Hp engines that had only 71 confirmed hours in fresh water. No issues were found in the pre-purchase engine survey and because of the timeframe, I had a 100Hour service done before I took possession. At the 100 Hours mark, I started having problems first with the port engine with tuliped valves and had that repaired. Almost immediately following (two hours later) I had the same problem with the starboard engine and in addition there was scoring on some cylinders and had the long block replaced and valves.
I took the boat out for a couple of hours (only TWO HOURS since the repairs) and had a head gasket failure to the port engine. Mercury confirmed and is covering the cost of those repairs. However, during the inspection, the Marina has found scoring in one of the cylinders and I am waiting for their next steps but my guess is another long block replacement. I am being told these issues are coming from overwork of the engines since they are the lowest HP Bayliner used and they have recommended switching from a 21" prop to a smaller one (perhaps 19"). After the initial repairs, I only had 1/2 fuel and two people on board and never went over cruise rpm (~3,800) so the boat wasn't loaded down at all.
My problem with all this is I purchased a boat with little hours with all factory spec/original equipment and I am having MAJOR engine issues related to factory "configuration". Since they boat is out of warranty, I am told Mercury/Bayliner won't help out on any of this and I am looking for some sanity checks and points of view of the issues and perhaps if I should bypass the marina and try to get to Bayliner/Mercury. I am also fearful that if I fix this again, I'll just see the same problems in a few more hours and I can't afford to keep fixing these problems at these intervals.
