I just bought a 1 owner 05 185br with the 3.0. Itll run 40 mph all it has.. its totally stock with the 21prop. My? Is a buddy tells me to drop down to a 4 blade stainless 19 whats this gonna do. Anybody else running these, or what are u guys running on similisr boat... im not all about speed by no means. But would like an all around prop any recommends
new guy help-gctid367748
When I bought my SS prop for my 1950, it was aroud 375 -400ish I believe. I tested a bunch of props to make sure I ordered the right one. I got it on there, took her out...... 400 bucks I got a little faster holeshot and maybe 1mph more tops. It really wasnt worth the extra cost.
If your boat isnt performing to your liking you can always look into a different pitch aluminum.
Unless you're planning to spend most of your time towing and Skiing you don't need a 4 blade on a 185.
Make sure you prop is not damaged, dinged, or bent. And it's fine.
Buy a killer stereo instead!:go-
Iy is the allumn from factory barely any paint wore off,i guess ill leave well enuff alone unless i see it becomes a problem. Thanx
