I want a dip stick that goes to the bottom of the fuel tank.
I pulled the dip stick and it ends far above the bottom of the tank.
I got suspicious of the short dip stick when i ran out of gas with plenty left on the gauge (at least 1/3)
Im used to work with metrics and not too sure on inches.
Can anyone guide me to what the tank fitting is supposed to be in thread size for my tank?
is it the same threads size for the barbed fitting that goes in the tank fitting?
Original is aluminum, does it matter if it is brass or alum?
Hans
Hans
