I would like to know however if using an adapter that splits the VHF Radio Antenna with the TV works. I would really only watch TV while docked at the marina if that makes a difference?
Splitting an antenna signal-gctid366715
I had one years back.......... PROBLEMS!!! Loss of power when I would transmit, Maybe the newer gizmo is better?? I would try a Google and see if you can find something.
BUCKANEER
:arr
Don't even think about it.
A VHF antenna is not resonant on TV frequencies. In fact, the matching network will attenuate the TV signals a lot.
Read this on TV antennas.
Besides, it causes problems with the VHF, which is your lifeline..........
Captharv 2001 2452
"When the draft of your boat exceeds the depth of water, you are aground"Comment
