Hi, my name is Darlene.
I owe a 2008 30Ft. 300 cruiser with twin 220 mercruiser.
I have a leak that is entering through a bolt into the core and bilge. I can access the bolt through the transom shower panel but tightening it does no good. I need to access it from the outside.
On the exterior port side near stern there is a 4ft long fin shaped panel that is open on the front and bottom to allow air in and out because this is where the blower vent is located. This is were the water is accumulating. Does any one know how to remove this panel. There are no bolts, screws or clamps and I don't want to force it off and end up breaking it.
Thank you
Darlene
Thank you
Darlene
