Drive ratio Bravo 2 on 1995 Bayliner 2859-gctid557597
    Can anyone help me with drive ratio info on Bravo 2 drive on 1995 Bayliner 2859 with a carbed 7.4? I have seen reference to both a 2.00 and 2.20 in my searching. Prop will be a standard 18 1/4 x 19. Thanks
    Most are 2:1 as my 1997 2859 was. You can look it up by serial number as well.
    iBoatNW
      BII Gear Ratios Available: 1.81, 2.00, 2.20.
      You can use the "drive gear ratio chart" to see what letter is stamped on the yoke (splined shaft)
      http://bluewatermarinesvc.com/pdf/me...ear_ratios.pdf
        OK, thanks for the info. I will check when I pull the drive.
