I am wiring 5 sealed LED light bars in my engine bay for some extra lighting. My question is, I need all of these to connect to a common terminal block, from there I will wire a main wire to the battery and put a switch in the middle. Is it ok to put a 12v positive terminal block in the engine bay or is that a no-no. Also do I need a special switch, or can a standard 12v heavy duty switch do the job without causing my boat to explode into 100 pieces? Should I be looing for a different solution?
