Last year on my last outing I unfortunately lost my starboard engine coupler. (gotta stop racing those cigarette boats.
) Good news is I had all winter to find one brand new at an unbelievable price which I have sitting in my garage right now.
I am pretty darn handy when it comes to mechanical work and actually removed/installed the engines in my boat. Unfortunately the boat is too far away and towing it to my place and back would set me back at least $1000 if not $1200. My plan is to go to the neighbouring house of where the boat is stored and have him bring his backhoe over my boat to which I will simply connect a chain fall to get the engine up high enough to replace the coupler. Most likely there was an alignment issue which I will take care of once changed and yes I do have an alignment bar. The Avanti I have is probably one of the easiest boat to get an engine out as the arch is reversed and the dual hatch doors open to starboard and port which leaves things wide open to work on.
Engine removal is a no brainer for me however I have never even looked at a coupling replacement before. Is there anything special I need to know before I get into this or is it just a question of taking the screws out of the old coupler and replacing with the new one, torqued properly and maybe a shot of blue loctite for good measure. Any pulling tools required or large pry bars or whatever to get the coupler off?
Any tips or pointer would be greatly appreciated as I will be 1.5hrs from home and do not want to go all the way back because I need something special to get the job done. Thanks in advance
