I just received my SS anchor roller/pulpit from Shawn in Washington. Does anyone have the dimension of where to cut the hole in the plate for the anchor roller? I will be using a 22# Delta as my main anchor and it will be fastened there.
2452 pulpit dimensions-gctid342744
I've got one of Shawn's pulpits on ours, but I'll have to get up there and clean the boat off to measure where the roller is at. It may be different beause we have a Bruce anchor. Looks like we have more snow on the way.
Larry and Susie
1992 2452 350 MAG ALASKA
1990 14' Johnsen/25 hp Evinrude FLORIDA
FWIW....., if a Windlass is in your future, let the chain swivel and anchor shank length help make your decision as to where to place the roller..... and consider how this would affect the gypsy location.... (assuming that you have some latitude here).
Rick E. Gresham, Oregon
I would like to install a windlass, but don't know if I will have enough fall height in the locker of the 2452. I currently have 25' of 1/4" chain and 200' of 1/2" 3 strand rope. I would like to install the Lewmar 700 horizontal windlass but have a concern that it won't work due to the shallowness of the anchor locker.
Some of us moved the Chain locker hinges to the side so it's easier to work around the open locker. It was a big improvement for me.
Carl
2452
I also have interest in the 2452 pulpit dimension and any recent contact info for Shawn or anyone manufacturing the stainless steel pulpit for the 2452. What is the most recent price and availaibility for the unit.
