I removed the defective (original) battery charger from my 00 ciera 2855. The one i removed is a Pro Marine Flyback 15 amp, 3 bank charger. It had failed and killed my batteries in the process. This weekend I replaced both batteries with new 27 series dual purpose marine batteries. I also removed the defective charger. I would like reccommendations for a quality, reasonably priced replacement charger. I have seen Noco and MinnKota units that look like they would do the trick.
My original charger was hard wired to the boats electrical panel. There are 3 wires providing power to the charger. Black white and green. I assume this is standard 110v wiring. Going on this assumption, if my new charger comes with a regular plug in for a wall outlet (most seem to come this way), what would be wrong with cutting the plug off and hard wire it like the old one was??
