I have a couple of stanchions (bow rail) that are cracking. The problem is, that they are through bolted (I assume), and the bolt end in the cabin is under the hull liner. So, that means that I have to cut the hull liner to unbolt the stanchions.
My question is, after I cut the liner to fix the rail, how can I fix the linerso I don't see the bolts punching through the roof??? It's a 2452 by the way.
