Why reading the manual is a good idea...-gctid363708
  • Why reading the manual is a good idea...-gctid363708
    Quick summary... bought first boat last summer, cracked block, yahda, yahda, yahda. When I would put the outdrive on muffs, water flowing, I never saw water exiting with exhaust... fast forward to this weekend. I removed the impeller and it looked alright. Then I looked in the manual and saw this:
    [img]/media/kunena/attachments/vb/666729=25668-1.jpg[/img]Then I looked at my boat and saw this:
    [img]/media/kunena/attachments/vb/666729=25669-2.jpg[/img]No wonder it never pulled water from the outdrive!!! Whoever installed that new hose is "something special"!
    I have the same engine that I "tended" to for almost 10 years and it still took a few minutes to realize what was wrong ! ops
      FYI:
      This is incorrect, unless it's for a RH Reverse Rotation engine..... and Volvo Penta did not use a RH REV Rotation engine!
      This is correct.
      And your current configuration is correct.
      Here's an example of a Sherwood pump that in terms of the impeller rotation and pump action against the impeller cam, is very similar to you Jabsco pump.
      The inlet/outlet are configured a bit differently.... but this too is basically the same.... just aimed differently.
      As the impeller rotates CW (as per this view), the vanes enter the cam and leave the cam!
      As they leave the cam, the volume between the vanes increases!!
      As the volume increases, it creates negative pressure pulling sea water in to the pump body.
      These then sweep the water around, and again, in a CW direction, until the vanes become depressed by the cam.
      When the vanes become depressed, positive pressure is created forcing the sea water towards the engine... and the cycle repeats for each vane.
      Attached files [img]/media/kunena/attachments/vb/666740=25671-Sherwood impeller bent over.jpg[/img] [img]/media/kunena/attachments/vb/666740=25672-SJE V 104 heat exchanger.jpg[/img]
      Volvo Penta Duo Prop Drives
        Rick,So If I hear you correctly, you're saying the sea pump suction inlet is the bottom port, not the top. Guess I still have a problem then!Update: I reread the manual... yep, I was looking at the wrong type of engine... I should have posted this pic:
        [img]/media/kunena/attachments/vb/666742=25670-3.jpg[/img]Thanks Rick! I can always count on you!
          You are welcome!
          Go back and look at my last post..... I did an edit to it.
          Yes.... you must have something else wrong.
          Have you replaced the water neck fitting?
          Have you replaced the lower pivot tube O-ring?
          Any suction breaches in the main suction hose and/or connections?
          Have you visited my BOC Vault page?
            Moral of the story. Way to much info in a manual, ask the question here at BOC instead.
            Cheers, Hans
            2007 Carver 41 CMY
            Twin Volvo D6-370
            Montreal, Canada
            Midnight Sun I Photos
              Hans, when he quits looking at Clymers and Seloc, he won't find these silly mistakes. :kidding
              The OEM Volvo Penta manual would never show a RH Rev Rotation engine sea water pump like this.
                Have not replaced the water neck fitting, pivot tube o-ring, but it sounds like they are probably the culprits. I'll check the hoses too and replace the impeller. As far as visting your vault page... yes, I've been there and have learned quite a bit... obviously, there's alot more to learn. Thank you again!
                  You seem so smart; I just don't understand how you only have a rep power of 31.
                    Gotta give you credit though, at least your reading something. Good job!
                      Look more closely................, it's actually a minus 31!
                        I tried...
                        [img]/media/kunena/attachments/vb/667015=25705-New Picture (2).jpg[/img]
                          whiskywizard wrote:
                          I tried...
                          Ya see, I told you..... it's the California outcome based education program all over again, and this time being applied to our BOC Rep Power.
                          • #14
                            i'll note surr whet youre telking obout - im a prodoct off thes celifornai skol sestems and i ok!!
                            • #15
                              Make sure the hole in the botton front of the lower unit is plugged or you will not get water to the pump, do not ask how I know.
