It got chilly last night on the boat! I turned the knob to "warmer" and turned the fan to "run" and all it didnwas circulate the cabin air. No heat. I have the switch on at the main panel. What gives??
Cabin heater?-gctid363640
More info needed!
Is this cabin heater electric or engine coolant heat provided?
I'll assume electric.
If the fan operates, this means that it's receiving a/c power, and it may indicate the electric strip, or a thermo switch that has failed.
Try turning the a/c power off, pull the cover and expose the element wire connections and the thermo switch connections.
Take some continuity test readings.
2850Bounty wrote:
More info needed!
Simo
2002 2855 350MPI Bravo III on Lake Champlain -> SOLD!
Shameless lurking on Lake Keowee with a Harris Cruiser 210 Tritoon/Mercury 150XL EFI
well..depends on the unit...if you have an airrrr heat/ac unit..it maybe set to ac only..which I believe is #1 on the pad..turn the unit off...then I believe you hold the fan button down until it displays..select up or down to get it to read 1 or 2...or 0 for both...1 I think is ac...2 heat...zero both.....(I'm not at my boat so can't verify with the manual)...
the other thing is the pump may not be working..in the engine bay there is a water pump that pumps outside water thru the RC unit to produce either cool air or hot air....depending on how it's set...
:arr ar
My seacock was closed. Opened it, still no heat.
I dont know what brand/model it is. Its whatever came factory on a 2000/2001 ciera 2855. There are 2 knobs below the V berth. One knob has 3 positions (off, fan, run) and the oter knob is temperature (warmer to the left, colder to the right. What is reverse cycle heat? How does it work?
