OK, so last fall when I was winterizing my boat for the first time (dealer did it first season) I had one of the heads of the blue drain plugs twist off! (see attached photos - end of red pointer)Tried using an easy out to remove, but the plastic is too soft.. just spins out. I soaked it with wd40 a couple of time over the winter, tried the easy out again with no success.So now what???Question, do I need to replace or can I just fill hole with some epoxy of some type of sealant to keep water from leaking?? This year 5.0 has a self draining feature... do I really need to pull drain plugs??Thanks in advance,
[img]/media/kunena/attachments/vb/666457=25652-Oopps!.jpg[/img]
