alternator help-gctid362889
  • captharv
    1. non enough info
    2. Read the below threads I wrote. This is a problem you will have to troubleshoot yourself, because I cannot take voltage readings remotely. I need thereadings to help you
    http://www.baylinerownersclub.org/fo...ad.php?t=36593
    Guest started a topic alternator help-gctid362889
    I have a 1987 2150 sunbridge with and omc5.7 and cobra out drive I put a rebuilt alternator on last year and it worked great for a few trips out I put it on right at the end of the season and it does not charge any more was wainting to know it there is a fuse of something that i need to check
