when i turn the key my gauge jumps to full no matter how much gas i have the float on the unit is free and moving. i took out the unit and moved float up and down but gauge stayed at full so to me that says the sending unit is jacked up. Right? just need someones thoughts on it
fuel sending unit? or fuel gauge?-gctid362384
The in-tank fuel sender is creating a variable resistance to negative. This is what gives the instrument it's value.
When you test the fuel gauge, use a test light to create the path to negative so that you do not damage the instrument.
Or if you can find a variable potentiometer of the correct value, you could use that.
You could even use another fuel tank sender outside of the fuel tank, completely circumventing the sender currently installed.
Connect it up, and raise/lower the float arm.
This should tell you if the gauge itself is working correctly or not.
Do NOT do any testing of any kind in/around an open fuel tank sender port!
Rick E. Gresham, Oregon
I was getting false readings on both of my gauges. Turned out that the floats on the sending units were no longer floating! Swapped out both sender units and all is well.
