The PNW has been reluctant to let go of winter this year, we get some 50*+ days and then the next it freezes and snows.
I've replaced the npt drain plugs on the manifold and raw water pipe with twist valves(proper name gets censored sorry), the factory exchanger takes care of the engine, but I still have to at least remove the impellor front cover to get the water out of it, so with ~45 minutes added to each end of a trip during the time of year when It could freeze I just don't go....meanwhile the outboard equipped boats are out bonking fish and somehow their impellor setup is self draining.
Is there anything I could do to my raw water pump to allow it to drain without reducing it's effeciency?
I was thinking of drilling and tapping a 1/8" npt hole in the bottom and installing another twist valve, but it would only get the water out between one or two of the impellor vanes...
