The original transducer that came with the boat (I believe) is an inhull hockey puck no way of knowing make or model. I was curious if could cut the cable, put a NMEA connector on it and hook it into my NMEA 2k backbone and have it work on my Garmin Chartplotter? I will add a garmin thru hull transducer but probably not until next year when I pull her out for bottom cleaning.
Old Transducer-gctid362233
