Hi Guys,Back again for another season and a few more questions. As I was putting boat away for the winter last year I noticed the right side rocker switch was flopping around like the spring tension was gone. So I guess it's time to replace the switches. My Question is can I replace it with a standard Trim Tab switch as seen in west Marine as shown below or do I need to find out the actual Hydraulic pump unit and get the matching switch, which would be the one on the boat now that needs to be replaced because I am thinking that there may be plugs that connect right to the switch or something like that. Also I don't want to have the switch to be a little smaller by chance and not line up and then the dash looks sloppy etc. Does anyone know where I could even get a direct replacement switch?
[img]/media/kunena/attachments/vb/665203=25537-switch.JPG[/img]
[img]/media/kunena/attachments/vb/665203=25538-write up.JPG[/img]ThanksEd
