I bought a 1984 bayliner capri last summer and the first time I took it out it was obvious that the starter was DONE. Sure enough I took a look and the starter was pretty beat up, there were metal flakes all over the place that had been ground off the part of the starter that contacts the motor (I have no technical knowledge, if you haven't noticed yet). I replaced it and it sounds nice and healthy now, only it will crank a couple times and then stop. I have to turn the key back to off and then try again. It will start after 3-5 tries.
Another issue that may be connected: It stalls in neutral fairly frequently, and if I throttle up too fast it stalls.
Thanks!!
Thanks!!
