Im burning these forums up and you guys and gals are probably tired of my dumb questions, but here comes another one:
My 2000 ciera 2855 (new body style) is equipped with factoy a/c. The air works perfectly and cools the cabin to 65 degrees in about 20 minutes and then i noticed the air coming out of the vents slows considerably. The air coming out is still cold, but the volume of air is reduced considerably. Is this normal? My question is, does my boat have a thermostat that regulates the airflow to control the temperature? I was under the assumption that the temperature knob was to control the temperature of the air coming out of the vent, not used like a thermostat. Does that make sense? Is there a problem with my fan/blower? Or is it normal for it to cut back on air flow as the cabin cools down?
