PLEASE HELP SUPPORT OUR SITE
Does anyone know or have quick access to measure the width of the factory swim platform on a 1994 2859? The dimension from the edge closest to the transom to the outside of the platform.
Thanks. Still going around in circles trying to decide how to mount a 9.9 kicker.
1) fixed adventure marine or custom fab bracket directly on the swim platform.
Pros: Quick, Easy
Cons: May need bigger slip or have to remove the kicker after each trip. With a 20" shaft may have trouble keeping the prop in the water in choppy conditions.
2) remote troll - swim platform mount with 3 or 6" drop.
Pros: Still a pretty simple install. Will drop the prop further into the water for better bite and maybe reverse. Can steer from anywhere in the cockpit.
Cons: Will definetely put the kicker too far back to fit in a 30' slip.
3) Direct to transmon
Pros: Most permanent install. Get's motor in best position. Won't add much if any additional length to OAL.
Cons: Have to modify swim platform. Probably remove entire port half of platform. Have to relocate battery charger, trim tab pump to find area big enough on inside of transon for proper mounting.
3) Notch an area of the swim platform to move the mount closer to the transom for either option #1 or #2.
Pros: solves the issue of adding to OAL.
Cons: Not sure if this leaves enough platform for mounting.
Shorten the swimstep. Greg can provide some pics of his project. That's what mine had and why I took the measurements for him. It's a really nice way to mount a kicker to a 2859.
Pros: Quick, Easy
Yeah I went the long way around starting with a couple of different swim step mounts and ended up shortening the swimstep and mounting the kicker to the transom. You are right I never could get the kicker to bite in any kind of a chop when mounted on the swimstep. I did have to relocate the battery charger a smidge, but nothing else had to be moved. It is by far the best option IMO.
Guys,Got the swim platform off today (man do they overdo the silicone bonding it to the transmon, never thought we would get it to let go).Laid out a quick CAD Sketch of the left side of the platform after the modifications you guys mentioned. I show a fairly large mismatch in the large outside radius between the two pieces. Am I misunderstanding where you made your cuts or was this evident also when you fitted the pieces together? If so, how did you hide this mismatch?
Hi Keith,I lined up the outside (stern) edge of the swimstep. The inside edge needs to be parallel to the transom which has an angle to it.Notice the angle of the tab on the right of this pic. I added a piece of plywood to the left side and then trimmed it to match the taper of the transom. In this pic the tab on the left side has not yet been trimmed.Hope this helps,Greg
I found you thread on the 2859'er site and that has a lot more helpful info.
One question. Do you know what the reverse angle of the transom is at that point? I saw you had to have your OB bracket modified, hoping to avoid this. I have some adjustment on my outboard, don't know if it's enough though.
