Prop size for a 87 2159-gctid360125
    Anyone know the stock prop for a 87 2159 3.0 4cy? I ask this last year and can't remember the size. Thanks, Mike
    probably began life with a 13.25 dia X 17P
    If the engine is still healthy and making good power, I'd start there.
    after that, use the prop that makes it run 4200-4600 rpm at WOT typically loaded
      Thank you, you gave me that Anderson last year and I went and forgot it.
