Coolant change on closed system Mercruiser advice?-gctid340236
  • Morecoffee
    This was exactly what I was looking for, thank you.
    E/G = ethylene glycol
    H/E = heat exchanger
    Assuming this is a Half System (engine only):
    To fully drain the old E/G from a 5.0L Merc, you must remove the side engine block drain plugs.
    Then remove the circulating pump suction hose and empty into a container.
    Have the H/E cap open while doing this.
    NOTE: The H/E's pencil anode port is not a drain for the E/G side.
    The circ pump hose should take care of the E/G side of the H/E.
    When re-filling, make sure that your thermostat has the air bleed hole in it.
    Best to use distilled water with your E/G.
    When fire up for the first time, do as you would with a car/truck.... give time for a bit of heat to just open the stat, shut her down.
    Check coolant level... top off... repeat.
    One or two Warm/Cold cycles.... and the air should be purged...... and you should be OK.
    If you have a WH or Cabin Heater, extra measures are required.
    You may also want to have the PH balance tested before you disgard the old E/G and get an idea of what's been going on inside the cooling system.
    It should be pretty simple. Pull a low water jacket drain plug, or a low coolant hose to drain the coolant, and then reinstall the hose or plug. Then put a mix of 50/50 antifreeze to water in the top filler cap. If you can put a bucket under the plug or drain plug to catch the old coolant that would make the cleanup easier.
  • Coolant change on closed system Mercruiser advice?-gctid340236
    I want to change the coolant in my Mercruiser 5.0 Alpa 1 Gen 2 closed system. I have never done it and it most likely should have have been done before now. Is there an existing thread on this? I have looked and only found Hino ones, nothing for Mercruiser. Any advice or a link would be appreciated.
    Cheers and Happy New Year
