1986 2450 Sunbridge ignition circuit on 11 volts; but 13 at fuse panel
1986 2450 Ciera Sunbridge Bayliner - I'm the original owner
Volvo-Penta AQ225A V8 with 275 outdrive and electric tilt (not electic trim)
I do not have shore power installed. My system is 12 volt only.
Problem: ignition circuit 11 volts at voltmeter, but 13 volts at main fuse panel behind control panel for boat wiring.
New alternator with regulator didn't solve the problem.
New voltmeter installed by Bayliner/Volvo dealer didn't solve the problem. It was also hard-wired (eliminated the "push on" quick connector, which didn't tightly fit the narrower bolts on the new meter)
New ignition switch installed, didn't resolve the problem.
Main engine/ignition fuse tests okay with multimeter (continuity) and under load (voltmeter.)
With engine running at 1,500 RPM, voltage at batteries is 12.8 to 13 volts on digital voltmeter.
I've cleaned every ignition circuit connection I can find, including the ground bolted to the engine.
When I use a jumper from the fuse panel to the voltmeter, it reads 13 volts. Otherwise it reads 11 volts. It reads the same with a digital multimeter in the 0-20 volt range.
An experienced mechanic told me that Bayliners have an engine wiring harness with a connection at the engine and a second connection in the hollow void space near the throttle and gear shift levers, on the starboard side of the cockpit. I have access to this space at three locations:
1. Removing the throttle/gear assembly (4 screws)
2. Where the wires from the control panel enter
3. An access hole under the vinyl trim panel on the starboard side, just behind the helmsman's seat area.
The wiring bundle appears to the fastened with clamps to the floor in the hollow void, slightly beyond my reach. I cannot find this "other connecter" visibly or by gently pulling on the wire bundle. Does anyone have an experience in locating this connector, or whether it may even exist?
Is anyone familiar with this low voltage electrical problem; Has anyone fixed it? If so, how?
I do have the 1986 Volvo Penta by Clymer with the engine wiring schematic.
Thanks for your help
Gary
"Prelude"
1986 2450 Sunbridge with Volvo AQ225A and 275 Outdrive
Long Beach Island, NJ and Florida snowbird
Gary
"Prelude"
