I'm getting a small amounts water running down the inside of the cuddy. Number one suspect is the stanchions for the bow rails because it seems to originate around the inside fasteners.
Number 2 suspect is now the through rub rail screws that hold the inside padded rails in place. Thanks to those answering my other post for the answer on how to remove.
I have access to most of the hardware for the stanchions except maybe those in the anchor locker.
What is the recommended materials and method to be sure this never leaks again. I should have enough room to raise the stanchions just enough to seal under them - even if I can't access the very front stanchions.
My guess is they were never sealed or were sealed incorrectly. I could suspect the way they jammed the winch wiring in behind the stbd rail but that would not make the port side leak too.
A minor tightening may have slowed the process down but after months of rain - it's time to shampoo again. I'd much sooner be proactive than reactive because it's not going to stop raining here.
I've considered getting a full cover but it seems overkill and the wrong approach, we already have a full enclosed HT and a rear sloping canvas.
On the bright side - all leaks are from above and not below- typical of most boats I've owned and this was the first from Brunswick Corp. We love our Trophy
