I've got a little tin fishing boat with a bow-mounted electric trolling motor. I want to charge the trolling motor's 2 deep cycle batteries by running my main outboard. The alternator has enough capacity to do this, but the outboard's alternator output is 12VDC.
What's there:
Has anybody tried the Yandina Trollbridge24? Is this the right way?
Here's a simple schematic. I have simplified it by eliminating the local ground and positive buss bars, fuses, breakers and battery disconnect switches.
http://baylinerownersclub.org/galler...serialNumber=1
What's there:
- A pair of deep cycles wired in series supply 24VDC to the electric trolling motor.
- Primary starting battery is a regular cranking battery; 12VDC.
- When plugged into shorepower, a 3-bank smart charger charges all 3 batteries.
