I wanted to share with you all a great solution to a plagued problem on the 32's. This weekend I removed the beauty rings on the two lights that are above the salon table. It took some gingerly twisting but eventually they came off after lining up the small tangs with the slots. I removed the incadescent bulbs (5w) and replaced them with a Lunasea high intensity LED's (3.5w) (Fisheries Supply) they ran about $17 each. WHAT A DIFFERENCE! the amount of light produced is easily 2-3x's that of the old bulbs and it uses 1/2 the amount of amps! Old bulbs ran about .7 amps and the new LED's run about .3 amps.
Hope this helps someone else!
Trev
Trev
