Well i guess I should have seen this coming!
I have 4 8d batteries joined in a series and hooked up to my new Xantrex 40 amp charger, with a combine button next to the ignition.
The batteries are just now approaching 2 years old. Amazingly I do not have shore power at my dock and the only thing keeping my batteries charged is my charger, when the genny is running.
So I always run the genny for an hour or 2 or 3, when im out and sometimes at the dock when im not going out.
This has worked far longer than I thought it would but recently, the port engine has been taking a little longer to start, turning over slooowly.
Now I waited 2 weeks to start her up and BOTH engines are not turning over. So today I got my little charger out, hooked it up for (fast charge) 10amps and let each of the first 3 batteries
charge for a little over 2 hours each. I just wasnt patient enough to charge the 4th battery, since it was getting dark.
Nothing! Both engines turned over very slowly and then, click, click, click!
So I guess the next step would be to isolate each battery and go buy a battery tester or meter?
See how all 4 test and which ones, if not all of them, need a real good charge?
I have always checked the water level every 4 or 5 months, so i know its not that.:surr
Any suggestions would as always be greatly appreciated.
Just dont have the money anymore to call my old boat electrician.
Thanks!:surr
Ed
Thanks!:surr
Ed
