Need Source for Teak Molding-gctid356082
  • Nikko
    billsguns wrote:
    ... The teak on your Bayliner is stained
    So I noted. any idea what's used to stain it? I'd like to match it in a few spots...
  • Papa_Charlie
    Thanks Bill, Matching stain has never been one of my strong suites.
    If you have a matching Issue take it to Daly's www.dalyspaint.com They will come up with a stain.. The teak on your Bayliner is stained
  • Papa_Charlie
    Thanks all. I appreciate your input. I will log all of these into my reference files.
    My Teak shouldn't be too bad to match. I just want to match that corner piece as it is used throughout the boat. Even the added closets in what was the third bedroom off the master has them. So shouldn't be extremely hard to find or if necessary have made.
    Biggest thing is I miss my shop. Now I have to rely on others to do what use to be done in short order.
    Thanks again guys for all the input.
  • SomeSailor
    Martin Plywood has the largest stock of exotics you could ever ask for and they're right in Everett. They have everything from Alder to Zebrawood and will sell a single board foot of any of it.
    VanHarper wrote:
    Edens Saw. Port Townsend/Tacoma
    Great place for wood!!
    Bofum are a loooooong way from everett
    WAY COOL MIKE
    I'll be in touch when I get home, in a year or two.
  • Nikko
    Kåre L wrote:
    Here's an outfit in Thailand that also do custom work:
    http://www.thaiteakmarine.com/
    I recently ordered an electrical outlet box from them, but haven't received it yet.
    wow - quite the place!
  • SomeSailor
    Yeah... but it's fun overkill... and it's the coolest thing Tommy. You just mount the sample piece, tell it to probe the original and then it makes a 3D mesh. You them just cut the stock with a 1/4" ballnose and sand. No work at all (and 60 inches per second).
    It can do some cool stuff:
    SomeSailor wrote:
    Pat; If you can come up with a piece that'll cover the materials, I can mill it on my CNC to whatever shape you want. Even better if you have a profile from an old piece, I can digitize it and extend it across the whole piece.
    Your Teak is new enough you should be able to find a board that'll work. Martin Plywood right there on Broadway (across from Wendy's restaurant) and they will sell you any shape or size by the foot. You'd only need a piece a few inches bigger than the finished trim.
    Leave it to you to use a CNC to do a table saw job
  • SomeSailor
    You might go to Crosscut Hardwoods in Seattle, check out the material available and ask them to recommend someone to mill up some corners for you.
    they are on first Avenue South
  • Johnny_Vintage
    Check these guys out. I've used them for a few projects on the boat and was very happy.
    They're not cheap but either is teak. They made me some custom stair noses for the companion way. Real nice.
    www.westwindhardwood.com
    They are located on Vancouver Island
