Ok a few mystery questions for you long time 45 owners. The compnionway light down to the staterooms worked once or twice when we first closed but darned if I can get it to work again. I replaced the bulbs thinking perhaps that was it. Which light switches on other 45's turn on the hall light? I "think" it is the 2nd switch down on the switches set on the outside edge of the galley, yes? The 3rd switch (out of 3) on that area is fixed and won't move...I assume it is just a blank?
the switch that is 2nd down from top in the bunk bed stateroom also does not seem to do anything and nor does the 4th switch down in the master stateroom. I assume perhaps both of those also turn on the hall light?
We want to upgrade the hall light but for now I will settle for figuring out how to get it to work! :arr
