Towing a large 'dinghy' - help sought
We have towed a reasonably large inflatable for 5 seasons now with very good results over about 2,500 miles. The boat is 19' long as weighs approx. 1,800#'s loaded and we tow off of both the rear cleats with an Amsteel homemade bridle. The bridle is really two large "V's" at each end so that we have 2 points of attachment on the towed and towing vessel alike. We have seen little affect on fuel use and have had zero problems towing both at hull speeds and cruising at 15-18 knots and even in heavier seas.
We know there are members on here who tow larger 'support' boats and we certainly could use some real life help and data on your experiences. We may consider towing a support boat weighing as much as 3,300 #'s fully loaded and would like appreciate your input both good and bad.
We are looking to learn these things:
- What is the heaviest you have towed
- What was your tow bridle setup (in detail please)
- What was the effect on boat speed and fuel usage
- What were the problems which you encountered along the way
Thank you ÔÇô
Ron & Karen
"NO WORRIES"
Thank you ÔÇô
Ron & Karen
"NO WORRIES"
