1991 3288 Flooring Replacement
  • 1991 3288 Flooring Replacement
    1991 3288 Bayliner Motor Yacht -- Flooring Replacement
    Is it possible to still find the original-style flooring (plank style) found in the Galley/Dinette areas. I need to replace the flooring in these areas and would like to keep it as original as possible. Any help to find a source would be appreciated.
    Mike Walsh
    p.s. I'm a new member and am having problems adding a Subject. It will NOT let me enter anything in this field?
    It is Teak and Holly plywood not planking. Hope that helps you direct the search to a specialty plywood dealer.
