2002 Bayliner 3788 Shaft Size?
  • 2002 Bayliner 3788 Shaft Size?
    Bayliners,
    Anyone know the actual shaft size for a 2002 Bayliner 3788? It's not listed in the manual. I'm pretty sure that it's 1.5", but would love a confirmation. Also need the diameter of the stern tube.
    My shaft seals are pretty much gone and I need to get replacements put in.
    Thanks!!!
    Edd M. Schillay
    Captain of the "Starship Enterprise" / NCC-1701-C
    2002 Bayliner 3788
    Venice Yacht Club / Venice Island, FL
    Our prime directive: Wherever we go, we go boldly.
    Depends on the horsepower. 1.75" for 270hp and 2" for 330hp. Easy to put some calipers to cfm.
      1.5" for 250 hp. No idea of the shaft log size
      Tony Bacon,
      Washougal, WA
      Caspian, MMSI 338355743
      Current: 1997 3788 Cummins 250hp CASPIAN
      Current: 2004 Yatchsman RIB WhatAboutMe
      Current: 1996 SeaDoo Challenger Scooter
      Previous: 1991 Catalina 28 sloop Vela Via
      Previous: 1984 Catalina 27 sloop Avalon
      Previous: 1970 era 4 man rubber raft Don't Honk I'm paddling as fast as I can
        Mine has 270's and using the caliper, I was able to verify 1.75" shafts.
        The shaft logs are either 3.25" or 3.5" and thanks to a bolt there, I couldn't get my calipers in there to be sure. Mechanic says to wait until the old seals are off, then measure, then order overnight. That's my plan B, but was hoping that someone here could verify the log size, so I can use Amazon points and order new seals for free.
        Edd M. Schillay
        2002 Bayliner 3788
          So if any needs the info for future reference, for my 3788 with 270HP engines, the shafts are 1.75” and the shaft logs are 3.5”.
          Edd M. Schillay
          2002 Bayliner 3788
