I replaced the oem hw heater with another Seaward about 7 years ago. It is not adjustable and heated water to 160-180° scalding hot. I installed a hot water tempering valve to reduce the water temperature to a more realistic 120° a week ago. Wow! What a difference. Gone is the hair pin trigger of getting the right water temp. Now shower and dish water temperature is much more consistent. I wish I would have done it 9 years ago! Valve was about $65 off Amazon. Misc parts about $30. Pex tubing cutter because I took the took the other ones home was another. $20. Simple job. The pic does not show it but I used plumbers strap screwed into the beam above to support the valve.
Hot water tempering valve
I love it, great idea!!!
Whats the weather like on the boat https://www.weatherlink.com/embeddab...59665f4e4/wide
Here is the link to what I bought. https://www.ebay.com/itm/153656306972
I cannot detect any difference in water pressure. Useable pressure might actually be better because I can open the HW at faucets up more without fear of scalding.
MV Kia Orana
Currently Enjoying the PNW
- Likes 2
Absolutely a great mod! I have been wanting to do the same. With this installed it opens a whole new plan for me. Since I installed solar I don’t really need to run my genny but for about 30 minutes a day. (Cooking) That is not long enough to keep hot water so I want to tee into the port. Engines water heat exchanger line and plumb it to the genny cooling system with a couple valves. I think this would allow heating the water in a few minutes instead of a hour plus. Anybody tried that approach?Cool Change - 1999 4788330 Cummins
Custom enclosed hardtop
Don't mess with the genset cooling system.
Not sure how you are sustaining batteries with only an hour a day of charging.
Asides I know that I can get a warm shower 12 hrs after the genset last ran.1999 Sandpiper Pilothouse - Current
Nobody gets out alive.
- Likes 1
Asides I know that I can get a warm shower 12 hrs after the genset last ran.Cool Change - 1999 4788330 Cummins
- Likes 1
Impressive results on the solar.
My day job involves me in cooling system designs quite regularly - the theory of taking some waste heat to the water heater makes sense. Practical execution of getting the system right isn't as simple as just grabbing a couple of unused ports on the block or going in line with the main Heat Exchanger.
I haven't timed it but it doesn't take too long for my water heater to get water hot after being depleted. Even if you could do it for a $100 that is probably ~40hrs of generator time and doubling the time you already run.... that would be 80 days on the hook to pay back.
The best thing you can do to extend the life of a generator is to run the generator regularly.
