5788 wiper motor removal?
OK don't know for certain about the 5788 but the 4788 uses a pantograph industrial wiper. One good place for replacement s is AM equipment. They were I believe the OEM supplier.
To remove or install the wiper you have the center nut on the shaft, and the two bolts on the shaft housing.
Whats the weather like on the boat https://www.weatherlink.com/embeddab...59665f4e4/wide
- Likes 1
On my 4087, I found a load of silicone on the inside that I sprayed with debond. With the nuts loosened, I had more success twisting the wiper motor to free it from the silicone versus trying to pull it. Not sure if the silicone was part of the manufacturing process or a previous owner…. Good luck…I also had to mcgiver a little puller to get the wiper off the shaft due to corrosion.
Originally posted by nfboater View PostOn my 4087, I found a load of silicone on the inside that I sprayed with debond. With the nuts loosened, I had more success twisting the wiper motor to free it from the silicone versus trying to pull it. Not sure if the silicone was part of the manufacturing process or a previous owner…. Good luck…I also had to mcgiver a little puller to get the wiper off the shaft due to corrosion.
