I will be installing my solar panels next week and looking to run the wiring from the arch (port side) down to behind the battery switch area. I’m wondering if anyone has made this run before and has any tips or suggestions before I start opening things up. I will be running three wires- all marine 10/3 wire in sheath. Thanks
4788 solar panel wire run
I ran my wires from port side of the hard top, across the arch and down into the electrical panel where I mounted the victron charge controller. It’s an easy run and then you can just attach the controller to the DC buss and use the existing big wire that goes to the battery bank. I used solar wire for all the runs and mounted the controller high up in the entertainment cabinet with a dedicated CB that can be reset. i
Cool Change - 1999 4788330 Cummins
Custom enclosed hardtop
That’s a route I never considered- interesting-it’s a long run from controllers to bank-have to check with my electrician on wire size-however if I went lithium I could put the bank under the forward couch which would be a much shorter run. Initially installing 2-450 watt rigid panels in series x 2 - each with its own controller- total 1800 watts. I have room for two more panels on hardtop but not sure I’ll need/ want anymore but want to run wiring just in case.
- Likes 1
I have two panels wired in series installed on the hardtop. The wire runs to the radar arch down the port side and behind the port side valance in the salon. It drops down behind the battery switch panel to the Victron controller mounted on the transom just underneath the cockpit floor. It enables a short run to the batteries.2000 4788 w Cummins 370's, underhulls, swim step hull extension
MV Kia Orana
Currently Enjoying the PNW
This is good info, thanks - as a new 4788 owner (with a hardtop) , solar is moving up the todo list and I have yet to explore all the cable chase options.. Curious if you can explain the cable routing a bit more? How/where did you bring the cabling "into" the boat on the bridge, how/where is the chase to get it into the salon area, how did you remove the valance etc..
Originally posted by yadda yadda View PostThat’s a route I never considered- interesting-it’s a long run from controllers to bank-have to check with my electrician on wire size-however if I went lithium I could put the bank under the forward couch which would be a much shorter run. Initially installing 2-450 watt rigid panels in series x 2 - each with its own controller- total 1800 watts. I have room for two more panels on hardtop but not sure I’ll need/ want anymore but want to run wiring just in case.
I just ran mine from the mounted controller to the positive buss wire behind the electrical panel, it was less than 3 feet long. The wires coming down from the roof are 10Ga solar wire bought off amazon (renogy). Since I have them wired series / Parallel you can see in the picture the voltage is near 40 volts and the amperage stays below 15 so the 10 gage is more than fine. I do not see any need to run dedicated charge wires from the controller to the batteries.Cool Change - 1999 4788330 Cummins
Whats the weather like on the boat https://www.weatherlink.com/embeddab...59665f4e4/wide
