Hello all,
I am still going through all my systems one by one on my new to me 3388 command bridge motoryacht, while I have in on dry land where any needed maintenance and repairs can be done more easily. I'm currently working on an issue with the steering system. I have noticed that the steering is much stiffer than it should be at both helms. I have already ruled out the hydraulic steering system as it has been properly bled, is not low on fluid, there are no leaks, and the pressure is correct and maintaining 25 to 30 PSI. In troubleshooting some more today I decided to pull the rudder bar and hydraulic ram off the rudders to see how they felt moving them by hand. They are very stiff. I have to use considerable force to move either of them in either direction. Don't quite need to use a hammer, but close. I tried the helms with the ram removed and both wheels move very smoothly with almost no effort and the ram extends and retracts correctly. So again, not the hydraulic system as far as I can tell. So my first thought was the previous owner never greased the tubes/shafts and looking at the zerk fittings on the rudder tubes, one is rusty and the other is broken off. On the rusty one, I cant get the small ball to depress using a screw driver either. So this makes my first thought plausible. However I'm not sure if just replacing zerk fittings and greasing would make that much difference. Could it also be that the boat is and has been on dry land since November 2021? I have read somewhere that the packing has to be wet to allow easier movement? When it was last in the water, before the purchase, believe it our not I didn't check to see how the steering felt. When we did a sea trial the captain provided by the brokerage didn't mention anything and I was involved in other things than driving. I just never thought to ask either. Another thought is, does anything need to be replaced inside the tube? I've heard packing has to be replaced at some point, but I'm not sure how often, or how to tell if it needs to be. There are also sleeves and bushings I've read about.... So of course I want to be sure if there is a problem it is taken care of before putting it in the water, as dropping the rudders may be needed. I've never dropped the rudders on any previous boats and have no experience having rudders repacked or rebuilt or repaired. I am considering giving it a go myself, but if its a challenging job that needs some more know how, I don't know if I should chance it, given I'd have to haul it out again if I do something wrong. Any thoughts and suggestions would be greatly appreciated.
Thank you!
Thank you!
