I’ve done a search both here and online but I still don’t know where the best location is to drain the coolant. I read there is a brass petcock near the starter but I sure haven’t found it. Anybody know where i should look or what is the best way to drain everything? Thanks in advance!
Coolant Drain Location 3888 Hino W04c-TI
W04 has the lower drain behind the alternator - it's built into the bracket. It's a, east-west facing banjo bolt (14mm wrench) and has a 5/8 (?) hose fitting coming off the bottom of it. It can be easily felt and wrenched by braille. Slip a hose over the fitting and into an aluminum turkey tray on the floor where it's convenient for you to be - dump AF into the tray, lift the hose up high to stop flow, dump the tray into a bucket, repeat. When dry, remove the banjo bolt, clean with a brass wire brush, use never seize and re-install. Move to next engine...________________
1998 Bayliner 4788
1989 Bayliner 3270 - SOLD-
