I just finisthed getting access hatch to cave installed and am about to replace my holding tank and all waste lines. Very similar to what many of you have posted about recently.
One thought occured to me is that if I ever want to replace the hot water tank now is the time. Replacing it would require pulling the holding tank, and since it will be out that seems to make sense. But I aslo noticed water heaters are pretty pricey. I am sure this is the original hot water heater, so it is 23 years old now. How long would someone expect these to last? If it is just a matter of time now, then I should just do it now. Also, any recomendations on water heaters?
While I am at it, should I replace the originally battery charger which is right above the existing tank. At a minimum I am going ot move it, but again if it is just matter of time I should just do it now. Again, any recommendations on it. I have a newer Xantrex/inverter that handles my house bank.
