Some of you remember my posts from the fall 2019 when I bought a 1989 3870 with fire damage from poor maintenance and the stbd turbo caught on fire causing extensive damage. I restored the floor and rebuilt both turbo kits, then enjoyed it for a year before the stbd engine completely failed in Sept 2020.
I knew this would happen, especially to the STBD engine. That engine had mainly lumpy tar in the sump when I did the first oil change, and the centrifugal was filled with carbon sediment. I got an oil pressure warning after a long ride one time, so I knew I was on borrowed time. My company specializes in engine conversions, in Land Cruisers, so in my mind I kind of just kept her limping along knowing I wanted more power.
I hired Earl, the local Hino guru to help with the engine portion, who almost talked me in to just rebuilding that engine. I kept pushing something with more power and finally he agreed with me. We searched for engines over a few months and finally a set of W06Ti mains came up in California.
I tore up the floor, he tore down the engine. I pumped the bilge, and he turned the wrenches ;-)
I'll update the build as we progress, currently the stbd engine is ready to be pulled, and the port one will be torn down and prepped before we remove both mains in the coming month. My boat is at Dagmars, so if you see me working down there, feel free to come cheer me on ;-) But if you see Earl, leave him alone to work - he's expensive LOL
Cheers!
Cheers!
