I know there are a few other 4388 owners out there and I thought I'd post a couple questions on some issues I'm struggling with.
First. I'm trying to get access to the back of the lower helm. I believe it has to come from the aft head. I can get the panels off the dash from up above, but getting to the back where I need to run a few wires has got me stumped. I'm guessing you need to pull the vanity cabinet, but not sure.
Second. I'm getting ready to put new toilets in both heads. I'm going to replace the waste lines and will be running a fresh water line and wiring. The rear head is no problem. But the front one is a pain. Is there any access to get to the chase where the toilet sits? IOW, I need to run plumbing and wiring from the cave, past the rear head, past the shower, to the front head and I have no idea how to get access.
Third. I'm getting rain water down into the bilge. Its coming down the rear corners. It seems as if the drains on the fly bridge, which lead to some 1" corregated tubing, must be leaking. Any idea how to disassemble those drains at the flybridge end? I can get to the tubing from below and by pulling some trim in the cabin, but I can't figure out how to get to the upper portion where it attaches to the drain.
Fourth. I'm getting ready to pull the cabin seating out..the portion that goes around the table. There is a kind of kick panel below the seat and I can't figure out what attaches it.
Thanks in advance. I'm guessing there may be some commonality between the 4388 and other models on a couple issues, but really not sure.
Thanks very much for any help.
toni
toni
