Marelon Thru Hulls
    Marelon Thru Hulls
    Specifically the 93 OEM series. Seems like a good product. I saw some of Mainsails destructive testing and they lasted to 800+ pounds of load before breaking. I'm thinking of replacing all the thru hulls in the forward part of the boat with marelon, and trying to track down a plastic AC strainer and just eliminate that part of the bonding system. If my engine intakes are bad, Forespar has a 93 series with a garden hose attachment for flushing. It looks pretty tight. Thoughts? I had planned to replace the ball valves on stems with real seacocks anyways when I hauled. They are coming out anyways because they were moving on the backing plates and needed to be reworked.
    Thanks!
    It seems counterintuitive, but may, in fact, be the right answer. What about long term degradation? My experience with the plastics out in the weather is they eventually Show crazing and/or become brittle. Without some serious education, if I were to be looking to buy your boat, my reaction would be “oh, hell no!” Are there any of the upper tier builders using them?
    • Cool_Beans
      Cool_Beans commented
      Oyster, Swan, Baltic, Morris, Catalina, Wellcraft, Boston Whaler, Hinkley, etc. I'll post a link to the valves.
    • Pcpete
      Pcpete commented
      Interesting. I took a look at their website yesterday. I guess I’m stuck in the “thru hull fittings should be bronze or stainless” rut.
    I agree the marelon thru-hulls are a good way to go...I use them for drain lines, but not on the macerator outlet.
    they are less than half the weight of stainless or bronze, cheaper, and can last just as long if they are installed properly.
    ive seen "budget" bronze and stainless thru hulls that were machined too thin after being cast, and broke off as they were being installed and tightened down.
    so if one wants to use the metal thru-hulls, I would be very careful of the quality of the cheap ones you can find on ebay... just because they look like good quality, doesnt mean they are, and just because one manufacture makes a mistake in their machining once in awhile, doesnt mean they all do all the time... I like budget priced parts, as long as the quality is there.
    NU LIBERTE'
    Salem, OR
    5.7 OMC Cobra - 15.5x11 prop
    N2K equipped throughout..
      If it's below the water line you want bronze, marelon is a good option for above water line thru hulls.
        Marelon is is rated for underwater use and is quite common. Real Marelon is nothing like the plastic thru hills used above the waterline on our boats. These thru hulls exceed ISO and ABYC standards for underwater thru hulls.
        2013 Boston Whaler 130 SS
        • Nauti_Mike
          Nauti_Mike commented
          Understood but what I stated is my position.
        https://www.defender.com/product.jsp?id=199316
        These things are far from budget. But they come complete as a rated assembly, ready to install. They are supposed to be rebuildable in the boat as well...they come with a plug in the handle to insert in the thru-hull. I may just go for it and see if there are any regrets later, hehe.
          I installed all new SS thru hulls, any from the engine bulkhead back under water tied tied into the bonding system.
          As a note, all wiring on my 3870 has been replaced with upsized wire.
          reason for re-wiring was the boat was sunk in the harbor prior to my purchase from the insurance company for $1300.
            Marelon thru hull & seacocks are quite normal on many sailboats, including higher end ones. I had several on our last boat and the only real worry was the handles breaking, The new ones from Forespar are supposedly improved quite a bit in several regards
            Here is a link to a thread with a good discussion and some testing results ( older and updated)
            https://forums.sailboatowners.com/th....136999/page-3
            Even with bronze you need to be careful (apparently) as not all bronze is created equal.
            Althea -- 2000 3988 270 Cummins, Hull Extension
            Semiahmoo, WA
              I only recommend marine grade bronze seacocks, no brass!
              There is a difference between a bronze valve and a seacock!
                I have a friend who owned a large boat repair business for almost 40 years. I specifically asked him about using Marelon. He said that the only issue he's ever seen in all the years he's been in the business was the shaft breaking on the original Marelon valves. He said the later valve design is fine and the thru-hulls have always been excellent. He would not hesitate using Marelon in a boat.
                He cautioned that it needs to be Marelon, and not generic plastic.
                  So I bought a 3/4" for the head intake and a 1" for the A/C (I'll neck down to the strainer). These are really cool looking and beefy pieces of modern engineering! I might pony up and replace my engine intakes with the 1 1/4" seacocks with built in hose fittings for flushing. I can post pics if anyone is interested.
