Boat ran for 6 hours and didn’t miss a beat. I start it every two weeks in the slip and warm motors. Today I started them, the starboard motor didn’t show any oil pressure and alarm was sounding. I checked the wires, they are all tight. And both oil pressure gauges go from completely to the left to 0 when key is turned on. Oil level is good and looks good. I ordered oil filter from Napa, it will be here Wednesday. Going to try that. I removed one of the oil sensors and turned over motor with stop button pushed in and the slow stream of oil never increased coming out of the housing. Bought boat about 2 months ago, trying to work the gremlins out. Has anyone ever had something like this happen?
250 Hino no oil pressure
No oil pressure showing at the gauge coupled with the alarm sounding has me thinking it’s possibly more than a sender or low pressure switch issue. Id still verify with a mechanical test gauge as Mike suggested.
something like this.
https://www.amazon.com/gp/aw/d/B0778...?ie=UTF8&psc=1Dave
"THE FIX"
Misc. projects thread https://www.baylinerownersclub.org/f...56-gctid789773
- 1 like
Originally posted by builderdude View PostNo oil pressure showing at the gauge coupled with the alarm sounding has me thinking it’s possibly more than a sender or low pressure switch issue. Id still verify with a mechanical test gauge as Mike suggested.
https://www.amazon.com/gp/aw/d/B0778...?ie=UTF8&psc=11997 Maxum 2400 SCR 5.7LX Bravo II
- 1 like
I am glad none of my engines need a tester with that range, can't imagime any seals standing up to that.
Any auto supply will have a oil pressure gauge that will work and only go to 80 PSI.
Don1995 Maxum 2400 SCR LUNA DE MIEL
1988 Bayliner 2455 (sold)
1976 Tahiti 16.5 I/O (sold)
Thanks for all the advice, I replaced oil filter today and bought an oil pressure test kit from Napa, I had a friend turn the key while folding the stop button while I looked at oil pressure gauge. Oil pressure was at 0. I then added oil just in case the previous owner replaced the dipstick and it was wrong..... no luck. I pulled the cap, spring and plunger out on the right side of the filter, it seemed to push back in and move easily. Trying to figure out where to go from here.
If you don’t have the manual for this engine get one. Then look to see how to change the oil pump. Also look to see if there is a separate oil pressure release valve. My knowledge on diesels is limited so I’m not sure where the oil pump or relieve are located and how accessible. When my 5.7 lost oil pressure I removed the belt and grabbed the crank pulley and could wiggle it around a little which told me the main bearings were gone.1997 Maxum 2400 SCR 5.7LX Bravo II
Had great oil pressure when we moved it after buying it, 6 hours. Then started and warmed up after a couple weeks. Went to start again and no pressure. Thinking bearings are good. Only ran for 5 seconds. I downloaded the service manual and am leaning towards oil pump like you said.... just want to make sure I’m not working myself to death.
I’m also not a diesel guy but like Mike I believe there should be an oil pressure relief valve in the system. These valves can stick in both the open or closed position, open in your case if that’s actually the issue.Dave
"THE FIX"
