Bayliner 38XX propeller tunnel extensions.
    PROPPELLER TUNNEL EXTENSIONS FOR THE 38XX
    I have one pair of 38XX propeller tunnel extensions available.
    The tunnel extensions are 18" long and bolt on to the transom to extend the prop tunnels approx. 18".
    They are constructed out of solid cast fiberglass and resin 18" long with a 3" flange for bolting to the hull.
    The reported speed increase reported is about 1 1/2 mpg at fast cruse, that depends on the weight and weight distribution on the boat.
    The tunnels fit the 38XX Bayliner's, I do not have other vessel sizes at this time.
    The $650.00 per pair plus shipping.
    Contact Pat Sterling on BOC "boatworkfl" and I will give you a phone number.
    I have installed a pair of these on my 3888 this summer and can verify I got a 2 kn increase in top end and cruising at 8 kn rpm dropped from 2100 to 1900.
    P/C Bob Hicks JN
    Dock Holiday, 1992 Bayliner 3888 Double Cabin Flybridge Cruiser
    Twin Hino W04TI 210 HP Diesels with Hurth HSW630A 2.0:1 Trannys
    Westerbeke 8.0 BTD-614 8KW Genset
    Avon 9 ft 6 in Tender with a Tohatsu M8B 8HP outboard
    Currently moored at Stones in Nanamio, B.C.
      Does not sound to me that it's worth it for such modest gains.
        I also pushes the water from under the swim step to straight back further.
        No complaints so far, at least 15 buyers so far.
        To each his own..
          Worth it for the fuel savings in the long run.
          P/C Bob Hicks JN
            Increase in speed, better fuel economy, helps bring the bow down, eliminates the spray pattern behind the swim platform- I think it’s one of the best additions I made to my boat for $700 bucks. I can highly recommend them. My wife says they reduced side to side roll in certain lake conditions. Lake Erie gets kinda snotty sometimes.
            Gibraltar, Mi.
            1986- 3870- Hino 175's
            1988 26' Shamrock/ Diesel
            14' Zodiac Bay Runner
              The price is now $650. plus shipping for the pair of tunnels. Pat
                boatworkfl
                Pat...every time I read posts about the tunnels I get more and more interested...couple of questions...
                1. Has anybody reported or have you noticed any loss of maneuverability at docking speed...spinning/turning...?
                2. Any reports of worsening control with following seas/wakes from quarters or astern...?
                Thanks...
                1988 3888
                Twin Cummins 6BT's 210hp
                Onan 8KW
                  I have not had any noticeable reduction in docking maneuverability and as for following seas I haven't been in any nasty following seas this summer to compare to but in mild following no difference.
                  P/C Bob Hicks JN
                    I have installed Pat's tunnels and confirm the claims of improved performance - including my wife and I agreeing that the boat rides better in mild seas.
                    I will also note that there is some loss of low speed response. But it is not significant to make any difference to me in handling the boat in docking or slow speed situations.
                    Regarding the following seas question the 38 has always seemed to want to plow into the backs of following seas - so I have always needed to match speed to sea conditions. I was afraid that the tunnels might make this worse - but I am still able to adjust the boat speed and reduce trim tabs to maintain good control.
                    Ron O'Blenis
                    B 38 175 Hinos 1989
                    Completed Great Loop
                    https://ronandfaye.blogspot.com/
                      Currently have no operable trim tabs and have no issue getting 16 knots. This was impossible before as our "little piggy" wouldn't do it. Too much stuff in it. I opted to bolt in, but countersunk the bolts and glassed in the whole thing. Works great and for the price is almost my best upgrade. The batteries and Magnum inverter is 1st (sorry lol ). Well based on price it is my best upgrade!!
                      1985 3870 175hp Hino's
                        Do you have any idea if these would fit a 4388? Or if you would be able to get ones that would fit the 4388?
                        Ships n Giggles
                        1993 Bayliner 4388
                        MMSI# 367412710
                        Day Island Yacht Club
                        Vice Commodore
                        • Sunbird
                          Sunbird commented
                          They only fit the 38xx models.
                        Hello, I'm interested in your tunnel extensions but am new to this site and don't know how to get your contact info.
                        email me with your number or? My email [email protected]
                          Hi Pat, Have been trying to reach you by phone regarding your tunnel extensions. Left messages on your cell phone. Could you please contact me.
                          thanks Marcel
                            Hi, I just purchased a pair of tunnel extensions from Patrick, will have to wait until I haul my 38 in spring
