Scupper replacement
    Scupper replacement
    My port scupper broke off where the down spout connects to the hose. How do I replace it? Is there a big nut underneath?
    Glen Sherwood
    1987 3270 twin 305’s
    Coupeville, WA
    Hi Glen
    If your taking about the Deck Drains in the Cockpit their Shower drains,and yes there should be a nut metal or plastic the rest should be standard PVC elbows,couplers.All available at local hardware stores .....Hope this helps....Brad
    Brad & Sharon
    Lady Jake
    LaConner,Wa. (summer)
    kailua Kona,Hi (Winter)
      Man that’s really hard to get to. Would you use a pipe wrench?
      Glen Sherwood
      Coupeville, WA
      • brad4550
        brad4550 commented
        I would use lock jaw pliers,maybe hold nut and turn drain assembly from top side??
      As long as your're in there...I'd consider upgrading the cockpit drains. Mine were 'way too small -- they rusted out anyway (as you'd expect a shower drain to do in salt). A wave over the stern would have been trouble. I got the scuppers from Fisheries Supply and probably got the larger thru-hulls from them as well.
      Good luck.
      https://www.fisheriessupply.com/perk...ockpit-scupper
Name:	port scupper.jpg
ID:	537404Click image for larger version
Name:	deck fitting.JPG
      100T MMC 2307794
