Barrier Coating 4588
    We are looking to barrier coat our 4588. Any recommendations in the Baltimore, Md area? Or a soda blasting company and good marina if we were to do it ourselves.
    Curious… do you have blisters on the hull now? I thought that Bayliner used vinylester resin next to the gel coat for a barrier coat. Have not seen any with blisters yet and some of those have been in the water 30 plus years.
    Greg
    Newport, Oregon
    South Beach Marina
      I have an early 3870 and no blisters as of this summer!
        I stripping mine to gel last spring. No blisters.
        I used Seahawk 1277 which is a primer and barrier coat.
        Irony
        1989 Bayliner 4588 - EH700TI
        Portsmouth, NH
          if does not have blister by now, it most likely never will is what i have been told by numerous boat yards over the years.
          Mark
          USCG OUPV
          1990 4588
          Carlsbad, CA
            Just surveyed. Had small blisters
              Where are the blisters forming?
                Starboard bottom center.... very little ones and a couple under port and starboard chine at midship.
