Seawater strainer top gaskets
    I need a hand with 1987-ish Bayliners using the Perko "figure 493/500 Sea strainer" I have the original 1987 install paperwork and it mentions gaskets but the part number is meaningless. I have a strainer marked Fig 493/500 sea strainer used for my Westerbeke generator. It has a top gasket that is about 2" diameter. The engine sea strainer says exactly the same thing but it is larger so the top gasket is about 3". Since I do have to open them up, particularly the generator strainer, to clean them; where has anyone been able to find these gaskets? My internet search has been fruitless. I have three strainers and eventually one of the aging rubber gaskets is going to fail.
    Fred
    Former USCG C130 Pilot
    Salish Sea Pirate
    Perko sells parts for them. I would bive them a call or email a photo to tech support.
      If you were in the Puget Sound area their are lots of Marine stores that carry the gaskets you need....West Marine....Fisheries Supply just to name a few.
      Brad & Sharon
      Lady Jake
      LaConner,Wa. (summer)
      kailua Kona,Hi (Winter)
        https://www.go2marine.com/product/86...eries-99r.html
        Cheers, Hans
        2007 Carver 41 CMY
        Twin Volvo D6-370
        Montreal, Canada
        Midnight Sun I Photos
          Thank you Friends. It is not simple, one has to know the "size" of the strainers. For us '38 owners of my vintage...the generator strainer is a 5 and the engine strainer is a 7. How stupid to give a multi-sized strainer the same model number. And the top gasket you need cannot be had without the glass cylinder rebuild gaskets, making the purchase way more expensive than need be. How many cyber gaskets will we simply be throwing away? And cork? C'mon, I don't want a single use gasket, I want the neoprene so it is reusable. Ruin the cork miles from home when the strainer clogs and you'd better have spares and time to spare to clean the surfaces. I ordered a cork set to measure and cut neoprene gaskets. Currently my boat had neoprene, but, Perko says cork is for "early model" fig. 493/500 strainers. I ordered a neoprene set, too, just to see what fits my boat best. How do you know you are early or late model-no information presented anywhere. Perko hoses us again. causing me strain(er).
          Not a "Newby", Just lost in an update.
          1987 3818.
          Fred
          Salish Sea Pirate
            I bought mine at Fisheries supply in Seattle some years ago.
              Flyboy, I have an 88 3818 and replaced the strainer gaskets just about three years ago. I’ve found the cork gaskets are multiple use. I tighten the top down just enough to stop any water flow plus a little bit. The old ones were dried out and well used. I bought the ones I have from Fisheries Supply in Seattle. I can’t tell you if they are cork or neoprene until I go to the boat and look at my spares, but I plan to go there tomorrow.
                Why not buy a sheet of Cork or neoprene/rubber and cut your own....have made a few that way.
                Brad & Sharon
                Lady Jake
                  Shut the seacock, open it up and take the gasket to any of the places mentioned, adding LFS. The cork are multiple use, but there are some other options. The cylinders are not glass, and each of them also has an upper and a lower gasket. If you have never changed them, maybe it is time. You already have the seacocks closed.
                  Tally and Vicki
                  "Wickus" Meridian 341
                  MMSI 338014939
                    When I couldn't find the correct model gasket quickly, i got a discarded heavy truck tire inner tube and cut a gasket to fit.....it is still there and working fine
                    Allan
                    1986 - 3870
                    175 Hinos
                    Moored in Ladysmith BC
                      I made my own from cork , could not find them at west Marine or the Parker store,, but I do live in Alaska
                      1988 3270
                      135 hinos
                      Seldovia ALASKA
                      KEVINS UPHOLSTERY
                      KEVINSBOATTOPS.COM
                      Marine canvas/Upholstery
                      since 1975
                        Just a suggestion - not sure if others will argue this or not. I installed one of these on my washdown pump on the sailboat two years ago and it has worked great for me. I have now recently installed one on my 2560 for the washdown pump.
                        This comes with the housing and the filter, they are readily available at your home depot and they keep the screens in stock too.
                        They are around 10 bucks, so it's not a bad idea to have an extra one in your spare parts bin on your boat. Also, if you need more than the 3/4" pipe size - one could put two of these in parallel if they have the room.
